print calendar
8133826 shared this problem 39 days ago
Published
From the calendar display, I click on View then Print but the print image does not match the screen image. The calendar days in the print image are in the lower right hand corner instead of the upper right hand corner as displayed in the screen image. Also, in the screen image the event is highlighted but the time is not. In the print image this is reversed. If I use the FireFox browser print option, the print image matches the screen image, therefore this is not an urgent problem but would be nice to have fixed. Thank you.
