Filter/Rules with rexep
8746872 shared this question 2 years ago
Need Answer
Hi, I'm trying to create a filter rule to fight with spams. I have enabled catchall for my @mydomain.com and as expected suddently I'm getting a lot spams :)
I need advice or help to create a rule to REJECT any mails if the recipient is not in my list of accepted aliases. eg
alias1
alias2
So I tried regexp (!alias1|!alias2)@mydomain.com but this doesn't work.
Any idea how to make this work?
Thanks!
Comments (3)
In case someone is trying to achive this, I was able to do it using Sieve filters (installed the plugin for Thunderbird)
## Flag: |UniqueId:4|Rulename:
if allof ( address :domain :is "To" "yourdomain.com" , not address :localpart :is "To" [ "myname" , "myalias1" , "myalias2" , "info" , "whatever" , "me" ] ) ## valid addresses, otherwise discard it
discard ;
stop ;
the syntax is: [^mail@domain.com]
Sorry - was thinking of something else with that last post. This should work:
^((?!alias).)*$
However I tried it and OX throws an error.
The good news however is that there now appears to be a "does not contain" filter rule so you can use that and avoid regex
