POP3/IMAP/SMTP problem
3680428 shared this problem 2 years ago
Published
I signed up for a trial account on mailbox.org to see if I can use it in automated ecommerce process (tickets, customer notifications).
I found in the documentation that it's possible to use POP3/IMAP/SMTP. So far my tests were unsucessfull. Is it because the account is in "trial" mode? Or it just doesn't work?
This is not password/port/other setting issue. Neither it's the system issue - it was sucessfully tested with gmail.
Thanks
Comments (2)
I have tha same problem. I turn off my firewall and antivirus from my desktop, i turn off firewall in router and set dmz to my computer but i cant connect to mail server
Try update your software mail client. My mailbox now works outlook 2016 after update software
