'Problem Deleting Key'
6121927 shared this problem 2 years ago
Published
I created a keypair before reading the explanation that they can only be used with your main address (I log in with mailbox.org but use my own domain for sending). So I deleted the key, changed main address to my domain and generated new keys (not without problems - took a few attempts for this to be successful).
Trouble is that the old, deleted key is still showing, after I thought I deleted it.
  • If I try to delete it with my alias (not the one that created it) as the main address, I get 'Bad Password'. But the password is correct.
  • If I set my main address to the one that created the key, I get 'Problem Deleting Key'.
How can I remove the keys?
