two questions about custom domain settings
TeCer shared this question 17 months ago
Need Answer
Hello,
i have configured my own domain with mailbox and now i can login with my email address.
I would like to know if i can delete the mailbox.org user that is now an existing alias.
I also would like to know if i can delete the TXT security key in my dns, or is needed for future aliases i want to create.
thanks.
Comments (3)
If
Sorry about the last comment, but sometimes this forum doesn't work well.
If you have set your "main address" with your domain email address then you can delete the mailbox.org address.
After that you can sign in with your domain email address.
About the TXT security record, I think you should not delete it.
ok, i deleted the "old" mailbox.org user without problems, now i have one more slot for my aliases.
For the TXT security record probably you are right, if someone can confirm this, just for info ...
thanks.
