Using aliases - trial account
4057860 shared this idea 3 years ago
Completed
I'm testing out mailbox to see if it will meet my requirements so I have a trial account for 30 days. I have created the one alias I'm allowed however I do not appear to be able to send as that alias. I see that there should be a drop down upper left to select this (based on the FAQs) however only my mail identity is there.
Am I missing something or is it an issue with the trial accounts (makes it hard to test an alias out if that is the case!).
TIA
Nigel
Comments (2)
Have you logged out and logged in again?
Thanks Peter - yes I have (several times) and I created the alias yesterday but there is still no sign of the ability to use it to send mail - I only get my default ID. I'd like to use mailbox but if I can't use the aliases it's not for me sadly. I don't think I'm doing anything wrong.
Best Nigel
Please contact support-en@mailbox.org. This is something our help desk team has to check individually.
Thanks Peter - mail sent to them. Regards
I do realise that support may be busy however it took a week for me to get an answer and they asked for a screenshot which I sent immediately and I've heard nothing for a week now. Sadly I think my trial will expire before I ever get a chance to test it properly. I think that is a pity.
Aaaah - got there with a helpful reply from support. However I had to login as the alias before it was available for use which maybe seems odd to me.
However it actually works very well I think - I'll try it some more tomorrow and hopefully sign up before the end of the week.
Thanks
