Error when deleting public key from Guard
Uli Fahrer shared this problem 17 months ago
Solved
Hi,
I want to delete my expired public key from the pgp.mailbox.org server, but the web interface yields the error "Authentication parameters are missing" in a pop up.
My goal to either delete the existing public key or revoke it and upload a new key of my new pgp identity. I don't want the old public key to exist uncommented on that key server. Also note that I don't want to extend the expiry of the old key as I want to use a new key.
Please tell me how to achieve my goal.
Steps to reproduce
  • Navigate to settings -> security -> mailbox.org Guard
  • Under Keys click "your keys"
  • Click the delete button
Expected behavior
  • Key is deleted from the server successfully
Actual behavior
  • Pop-up with error "Authentication parameters are missing"
Details
{"error":"Authentication parameters are missing","error_params":[],"categories":"ERROR","category":"ERROR","code":"GRD-AUTH-0005","error_id":"-1564773354-19623109","error_desc":"Authentication parameter missing.","error_stack":[]}
Replies (1)
I contacted support with my problem. I leave the solution here for reference:
In order to delete the public pgp key from their server the guard extension must be reset. To do so you need to contact support.
