Anti-spoofing for Custom Domains (SPF, DKIM & DMARC)
2153638 shared this question 10 years ago
Need Answer
Does mailbox.org offer anti-spoofing options for custom domains? I can find no information about this on the help pages. Other privacy-oriented providers, e.g. protonmail, do offer this (see here: https://protonmail.com/support/knowledge-base/anti-spoofing/).
Mailbox.org should make information about SPF, DKIM and DMARC easy to find.
Best Answer
Hi there and thanks for hanging in there with us. We totally get the challenges you and other users are facing with implementing anti-spoofing measures for custom domains on mailbox.org.
Just to let you know, it's definitely on our radar, but it needs careful planning and thorough checking of all security aspects.
Additionally, SPF settings are being honored and DMARC settings are a huge factor in our spam recognition. While we don't honor DMARC at a 100% right now, we do take it into account.
Rest assured, we're committed to this and grateful for your continued support and understanding.
Best regards from your mailbox.org-Team!
Replies (42)
You can always just check the DNS Records yourself.
Short anwer: Yes, mailbox.org uses SPF, DKIM and DMARC.
Long answer: Everyone can send Emails in your name anyway. The mailbox.org SMTP servers do not check if you spoof your from address. See this discussion in the german forum: https://userforum.mailbox.org/topic/mailbox-org-smtp-server-stellt-mails-mit-gefakten-absender-zu
Gmail antispam system uses DKIM and DMARC. If I send an email with my custom domain to a Gmail user that will may be redireced to spam
I actually have this exact problem. Using Mailbox with custom domain and some of my mail is marked as spam by default on Gmail. The weird thing is that not for all Gmail recipients, but only for some.
Any idea how to resolve this?
I have the same problem, I'm using every method available to increase authenticity of my own domain's email to avoid spam filters, but Mailbox's ip addresses are blacklisted at some anti-spam organizations. I emailed support about this and they responded that they're working on resolving this.
Yes. Also heard of it. They’re working on their outbound structure to solve those issues.
Hopefully it will work.
Following this article: https://kb.mailbox.org/display/MBOKBEN/Using+e-mail+addresses+of+your+domain (namely DKIM and DMARC) resolved my issue. All mails are now successfully delivered.
The easy way is to use openssl and generate your private and public keys with this:
  1. openssl genrsa -out private.key 1024
  2. openssl rsa -in private.key -pubout -out public.key
If you want a 2048 bit key change "1024" with "2048".
With a TXT record you have to add:
  • dkim._domainkey.yourdomain.TLD as a host name (change "dkim" with everything you want e.g. "default, key1" etc).
  • in the value part v=DKIM1; k=rsa; p=your/generated/key
The SPF it's easy and reported in the support section of mailbox.org site, just add in a TXT record: v=spf1 include:mailbox.org and leave the host empty.
DMARC it's just a string, you don't have to generate nothing, again in a TXT record put:
  • _dmarc in the host part
  • v=DMARC1; p=none; rua=mailto:youraddress@yourdomain.TLD
(You can create an alias just for DMARC like reports-dmarc@yourdmain.TLD)
You can find openssl for every GNU/Linux distro and also on Windows I think.
Hope this helps you.
In order to use DKIM private key should be saved on mail server and public key in TXT record as shown above. It's impossible to setup DKIM by yourself without Mailbox.org support.
True, I was wrong.
It's not working in our scenario, because we don't have backend access to mailbox.org servers.
So, the previous post was wrong, unless you have your own server or a cloud VPS and running Postfix, Dovecot etc by yourself.
I'm happy to say that the mailbox.org team added DKIM and DMARC support.
In the knowledge base there are all the info. You can check it here https://kb.mailbox.org/display/MBOKBEN/Using+e-mail+addresses+of+your+domain
There's a detailed explanation of how to add DKIM with your domain.
Hope that is helpful.
Wonderful! What is `_domainkey` in the DKIM section, though? Is the the subdomain or the content of the TXT record in the SPF part?
No, it's a standard for DKIM key records.
You have to literally write MBO0001._domainkey on your TXT record, in the subdomain section.
If you check other providers it could be like google1234._domainkey or yahoo1234._domainkey.
So, ._domainkey it's the standard part. The name of the key is the part before.
Ahh, stupid me! Thanks a lot!
6
Hi,
BUMPING this topic.
it's look like anyone with a valid mailbox.org account can send mail with domain configured on mailbox.org
E.G. Your account : toto@mailbox.org you can send an email as bidule@adomainname.com if a adomainname.com is configure by another mailbox.org user on mailbox.org,
If you try to spoof an address <something@mailbox.org> It's rejected.
I find this topic looking about DMARC.
I've two mailbox.org account, for different purpose. I tried by configuring Thunderbird to use my first account and spoof random address @mailbox.org and randomadress@mydomain on my 2nd account
I check the result in a test gmail address.
I would like to know what I need to configure to avoid that on mailbox.org, is DMARC the way to go?
For now I've only SPF & DKIM configured.
I read a little bit (https://userforum.mailbox.org/topic/mailbox-org-smtp-server-stellt-mails-mit-gefakten-absender-zu) answer with a translator but I don't get everythings, as I don't read german.
I just tested this and you are correct. This is extremely troubling.
I have SPF, DKIM, and DMARC setup and I still managed to spoof an email not connected to my account.
I'm a bit confuse , I opened a support ticket as the support didn't reply here ? (after 49 days)
I have been talking with the support about this and they are saying it’s intended.
I tried to explain the issue further now and I am waiting for another answer.
Meanwhile, I moved 5 users away from Mailbox.org.
Dam! That's terrible, How this can be intended as it's block for the default domain @mailbox.org ?
I hope I'll get a positive feedback from the support, and I hope you are wrong ! but current facts make me think you are not :(
I like the service, I don't really want to move again, when I did this research for DMARC, I was planning to transfer more domains & more accounts to mailbox.org :( :(
5
The possibility of using different sender addresses was introduced some time ago due to a a mistake/misconfiguration. Unfortunately, it's not that easy to stop that, since we have many business customers that use us as a mail relay and/or that re using catch-all addresses.
Right now, we're on the way to stop this; we're logging every sender/user mismatch, analyze it and contact users that are sending legal mail without having this account registered in their user data. This takes a lot of time and is difficult.
Hopefully next weeks we'll be able to switch from warn- to reject mode.
This project started in autumn, but making that big/important change in Christmas time isn't a good idea if you have many business customers. It was postponed to spring, but also now, during corona time, many users and companies had much more important stuff to do (also we had), so adding some extra technical issues isn't still good idea. We'll activate this if everybody all over the world calmed down and we had the chance to analyze everything and to minimize the impact of such a change. -That's why "stupid and ease looking changes" take sometimes 9 month even if it is on the roadmap and even if activating that block would take less then 10 seconds...
Do you have an update here?
I created this issue long time ago https://userforum-en.mailbox.org/topic/spoofing-protection-again
But, as I checked a minute ago, mailbox doesn't check SPF and DMARC. It's still possible to spoof my custom domain
I just tried sending as <spoof-test@mailbox.org> (obviously not me, and sorry if it pops up in some logs :-). It went through with DKIM signature and all. If I read Thom's post from 23 months ago correctly, it should have been rejected instead? What is the status here?
FYI, the reason I tried is because I read about it on HackerNews where it’s discussed as a possible security issue: < https://news.ycombinator.com/item?id=30224906 >
I would also be interested in knowing if this changes have been implemented.
We have created an internal team in order to approach this issue.
Please bear with us.
Is there any update on this issue?
Hey Support,
When can we expect an adequate level of security from your service?
Your website proudly states: We will do everything to protect you.
Yet, two years have passed, and it is still possible to spoof email from private domains.
Thanks
Is this still an issue?
We already have taken measures internally and came up with a plan to remedy this.
In addition we have scheduled a meeting next week where we will discuss further steps.
We'll keep you posted on the outcome.
We want to fix this quickly.
5
What was the outcome of the meeting?
@mailbox.org Support: If I understand correctly this actually violates your IT-Sicherheitskennzeichen from BSI on the point "Stand der Technik" in that it seems that you aren't fulfilling "Das Schließen von bekannten Sicherheitslücken."
There is an online form to report such "Schwachstellen und Sicherheitslücken" which I am feeling inclined to submit due to the lack of action on your end.
Could you please clarify/make a statement?
Thanks.
I would like to ask why mailbox does not honour dmarc settings.
i have two personal domains, both with dmarc set to reject. domain1 on mailbox.org and domain2 on zoho.
Using a fake mail service if I send a spoofed email from domain1 and domain2 to mailbox.org the emails arrive in the inbox, if I do the same to zoho the emails do not arrive.
Why has this not been resolved?
Good question. I also asked this several times and no feedback - maybe because it's not solved at all could be the answer.
Would be nice to get some official feedback.
There are also some threads within the german forums about it.
https://userforum.mailbox.org/topic/6425-weiterentwicklung-von-mailbox-org-wie-schaut-es-mit-dem-fokus-auf-das-kernprodukt-e-mail-aus
can we get updates regarding the anti-spoofing fix?
at the moment spf/dkim/dmarc settings are ignored inbound from mailbox.org, i can receive spoofed emails from any domain either on my custom domain or mailbox.org aliases
I can understand the issues described by staff in previous posts but it's been over two years and we're not talking about implementing a new interface theme or adding optional features, this is a basic security measure that any normal email provider has.
If you do https://emailspooftest.com/ emails e5 e7 and e9 come though which they should not.
When is this going to be fixed
Really like to see some kind of update here.
If you are unsure about details, you could still add it as optional feature in https://kb.mailbox.org/de/privat/e-mail/den-mailbox-org-spamfilter-konfigurieren/#smtp-plausibilit%C3%A4tscheck
For me, I tried out https://emailspooftest.com/ and also got some of the emails in my inbox. Of the emails which got through I looked at the headers and see:
* E3 fails with `spf=fail` and `dmarc=fail`
* E5 fails with `dmarc=fail`
* E7 fails with `spf=fail`
* E9 fails with `dmarc=fail`
All of the emails are easily markable by a system. Even my email client (FairMail) correctly marks them in the inbox.
Also, some of the mails got a really big spam score but still arrived in my inbox instead of the spam directory. Could there be some issue when a filter matches on a mail which is detected as spam?
5
Hi mailbox.org-Team,
any updates on this?
Thanks!
Hi,
I am currently in the trial period, evaluating the service to create 2 accounts on mailbox.org with several custom domains. So far the tests were very satisfactory, but this problem makes me think about looking for other alternatives because it is an unacceptable security flaw. Any realistic solution plan? Because it has been more than 4 years since it was reported and it is still unsolved.
This is becoming more and more pressing, due to the upcoming DMARC requirement for large-volume email being enforced by some major email providers starting tomorrow. Those of us who don't send thousands of emails per day are okay for now, but the rumor mill seems to imply that won't be the case for very long.
Here's Google's information on the topic.
Here's Yahoo/AOL's blog post.
Sorry, I don't have German primary sources for this information, though there are a few third-party blog posts.
5
Is there any update, or timeline for the problem to be fixed?
Can we please get an update about the current status in this topic?
Are there any updates on this? E-mails that fail DMARC and DKIM are not flagged or put in junk when DMARC policy is "quarantine", and this is a big deal. E-mail spoof tests show that you do not respect DMARC policies set by the domain DNS records.
For those interested, people are discussing this elsewhere: https://discuss.privacyguides.net/t/remove-mailbox-org/20232
This is also deeply concerning for me. My domain now gets an F rating from https://emailspooftest.com. Unauthenticated email sent from my own domain to me, despite my quarantine DMARC policy, appears right in my inbox!
Making me rethink the switch I made to your platform. Crazy.
It's disappointing that Mailbox.org's blog post today promotes its custom domains (Email address with your custom domain: introduction and tips), yet this serious issue has continued to go unaddressed, with very little communication other than occasional reassurances that it's being worked on, for years. I'll be moving off this platform.
I have just done https://emailspooftest.com/ just now and the only mail that should come though is E1 which is an email to say about the tests etc, and it looks like the issue has been sorted etc it has not, and I thought it has been sorted. But then suddenly Emails e5, e7 and e9 are the only ones to come though.
Mailbox.org really need to make this a number one priorty to fix and sort before working on other things. I know alot of people would use IM systems such as Signal, but email is a universal commications system and for signing up to online accounts. not fixing this bug could cause issues with other providers such as mailbox.org emails going into spam.
5
I agree with the comments above. To be fair to them though, I've tried that test with MS365 outlook, iCloud, Proton, Infomaniak, Zoho and they all fail in various ways. If I remember correctly, the only one that had full marks was forwardemail.net, but I don't know if I trust them enough as a company to use them. Infomaniak let E1 through, as it should, and then E7 too, so not too bad. Proton let E1 and E7 through to the inbox and E3,E5 in spam. iCloud E1, E9 and E7. Some of them went to spam when they should have been completely blocked. But ending up in spam is better than in the inbox like with Mailbox.org -- E1 in my inbox (as it should be), together with E5, E7 and E9.
I'd love to hear from Mailbox.org about this though to know what the status of their updates are. It really does't look good for a privacy-oriented service to fail a test like this.
Just to add that I tested Zoho Mail again and it actually performed perfectly, with just E1 in the inbox and none of the others delivered. Why can't we have that in Mailbox too?
Hello, I'm a new Mailbox user (using a custom domain) wondering what's the status of this issue. I probably should have done better research before I signed up but it never really crossed my mind that an email provider that's been around a while wouldn't be following normal security standards. Yes that sounds rather naive on my part when I put it that way!
Currently my dmarc reports are mostly OK, DKIM and SPF pass though testing my account with emailspooftest was pretty bad as discussed above.
Anyway I still have time to switch providers and it wouldn't be much effort at this point, what would be the general recommendation here?
5
It’s not great, of course, but it seems other services don’t do that well on this test either, including Proton. In my very limited/personal testing, it was only Zoho that scored perfectly, but they have other issues. There are no perfect providers with perfect security and privacy, so I’d say stay with mailbox if you like it! Seems like a good service to me and hopefully things will improve with the upcoming major update they has been promised.
Before I continue and waste my time to setup any custom domains or even consider to start using mailbox - this is not true, right?:
"E.G. Your account : toto@mailbox.org you can send an email as bidule@adomainname.com if a adomainname.com is configure by another mailbox.org user on mailbox.org,"This would make the whole domain verification step useless.
SPF/DKIM/DMARC is not implemented properly for incoming emails "only", isn't it? While this would be a bummer as well, but not as bad as the statement above.
Still not sure if I can accept the idea of using a (in comparison high priced) paid service that doesn't take standards into account that have been there for years or decades.
Seems like this has not been resolved.
Ran the same test as specified earlier and mailbox fails E3, E5, E9 and E1 Never gets delivered.
Just ran the test, E1 and E5 got delivered here - what is the advised course of action? Do I understand correctly this is about inbound mail to me, not about receiving servers which should have bounced these emails as they only appeared to have come from me?
[edit]
E3, E7 and E9 also just came in
It's about mailbox.org servers that do not comply to basic SPF, DKIM and DMARC rules, even after years.
For me it is most likely the time to discontinue the usage since they just don't care.
It is about trust and how a business reacts to reported and well-known issues.
The weird authentication, email delivery delays, lack of proper spam setting controls are just some of the other reasons.
My emails are getting rejected from my receipients' mailboxes due to:
Remote server returned '550 5.7.509 Access denied, sending domain "wff.eu" does not pass DMARC verification and has a DMARC policy of reject.'
Can someone please help? Should I cancel my subscription and move to another provider? At a total loss and so annoyed to be paying for an email service that doesnt work!
Thanks so much in advance!!!
Tried it, hopefully it works now… thanks so much!!
There are some errors in the configuration for wulff.eu. Why not take Flo's advice and create a new thread to discuss.
For what it's worth, I have no problem with delivery. Have you made sure that DMARC and SPF are all configured properly?
Hi there! I followed all the instructions and now I received 3 emails with this header: Report domain: wulff.eu Submitter: google.com Report-ID: 81120....7... is there is a problem? Thanks so much for all your help!
You can just put "v=DMARC1; p=none;" in the DMARC TXT record and leave the part that makes it send these reports.
https://serverfault.com/questions/1097230/is-it-ok-to-set-up-a-dmarc-record-with-no-rua-and-ruf-tags
It's the DMARC reports that can be used to identify potential problems with your email traffic.
Please don't get me wrong, but you should really read about the basics of SPF, DKIM and DMARC when you want to use a custom domain and get a basic understanding. Do not jut copy any snippets and throw them in your DNS blindly.
It can be overwhelming in the beginning and as a last resort maybe a simpler approach without custom domain is more appropriate in the beginning, eg posteo.
PS: this thread is about Anti-Spoofing, please create a separate thread in case you need assistance and keep this thread clean and related to the topic.
Thank you
Yes thank you very much I will stop posting here!
Any updates?
5
I cannot believe this problem still exists after 9 YEARS. I can still send myself spoofed emails using https://emkei.cz/. Even Gmail will reject those spoofed emails. My domain is "liups.net".
What is the last response from mailbox here? Was it 2 years ago? Time for mailbox to clarify and give some updates..
6
Can we have some information about the progress made in resolving this issue?
The fact that I can receive fake emails from any domain (even from mailbox.org) in 2025 is completely unacceptable, especially from a provider that prides itself on security.
I appreciate the fact that you are one of the few providers to implement DNSSEC and DANE/TLSA.
I appreciate your TLS checker in webmail.
I appreciate the BSI's IT security label that certifies the technical guideline “Secure email transport.”
I appreciate the implementation and management of PGP keys
I appreciate many things about Mailbox, including the value for money in relation to the service offered.
However, it is not acceptable that every time I receive an email that I consider suspicious, I have to check the source because I am aware that even though the sender appears to be correct, it could actually be anyone.
This overshadows all the security practices you have put in place.
For what it's worth, privacyguides.org is discussing removing mailbox.org from its list of recommended email providers. Discussion is here
I was looking forward to the black friday deal this year and was planning on migrating as mailbox has almost everything I was looking for in an email provider but this is a pretty big issue... :/
It looks like this issue has been fixed now (the problem discussed here: https://news.ycombinator.com/item?id=30224906). I was not able to send from my own domain on an account that is not part of a family or does not have an assigned email address in that domain.
SPF, DKIM, and DMARC can help, but the receiving server also needs to be configured correctly. Most servers will just mark emails as spam, but some (or if you self-host one) can reject spoofed emails.
For example, DMARC tells the recipient server what to do with emails when SPF or DKIM fail validation. (The test at dmarcian.com can guide you to set it to “reject” if you want full protection.) But this is only half the picture. For instance, Stalwart allows relaxed, strict, or disabled DMARC policies. A relaxed policy will only enforce rules if an email fails or passes, otherwise it just marks it as spam. A strict policy will reject anything that doesn’t pass verification.
So yes, you can tell the recipient server what to do with emails from your domain, but ultimately it depends on how that server is configured.
I can confirm that sending an email through mailbox.org SMTP, while pretending to be a different mailbox.org account holder, does not work anymore, at least not straightforwardly.
The attached image shows my attempt on the Android email client, FairEmail.
Friendly reminder to anyone reading: remember to strip metadata from whichever files you publicly upload to the internet.
test results still don't look promising
receiving E3, E5, E7 and E9
Same, I can confirm this is still happening; I recieve E3, E5, E7, E9 and never receive E1.
I did a lot of testing with different providers. Posteo gets the same results as Mailbox by default. I say by default because Mailbox and Posteo allow us to create rules that apply to headers. So I created some to put emails that fail spf or dmarc in spam. I could have chosen "reject with reason" but wanted to play it safe there.
Now E3, E5, E7 and E9 end up in spam instead of inbox.
Of course it would be better if Mailbox (and Posteo) were already treating these emails as spam by default.
Protonmail gets better results without touching anything last time I checked (I don't have an account there anymore), And Infomaniak too, but I didn't like their anti-encryption stance and their kyc is a little bit aggressive.
Tuta default configuration is the best of all providers I tested. E3, E5, E7 and E9 go directly in spam.
Be so kind and post your rule set.
I did something similar, these are mine (roughly). I did them as separate rules.
Conditions
	Header
		Regex: (\s|;|^)dkim=fail(\s|;|$)
Actions
	File info
		Select folder: Spam
Conditions
	Header
		Regex: (\s|;|^)spf=fail(\s|;|$)
Actions
	File info
		Select folder: Spam
Conditions
	Header
		Regex: (\s|;|^)spf=softfail(\s|;|$)
Actions
	File info
		Select folder: Spam
Conditions
	Header
		Regex: (\s|;|^)dmarc=fail(\s|;|$)
Actions
	File info
		Select folder: Spam
you can also do it with this rules
This is not to throw shade at @TeCer, but their rules still allow the emails from emailspooftest.com through. The rules by @AP do filter them out, but you can avoid regexes by using Contains instead. Of course, you can also combine them by using "Apply if any conditions are met".
I don't understand all the details about the email authentification, so maybe it makes more sense to take the policy field into account, as done by @TeCer, I'm just saying that emailspooftest.com is not happy about them as is.
I use regex instead of contains for 2 reasons:
  1. The authentication results header contains some additional data other than the (dkim/spf/dmarc)=(pass/fail) and I don't know enough about how those values are produced to know if a similar something=something substring can sneak in that a contains would trigger on.
  2. I have other rules for handling ARC-Authentication-Results headers that looks for arc=pass in Authentication-Results and I don't want it to trigger due to dmarc=pass that contains would trigger on.
Not all of them may need to be regex because of those reasons but I just did all of them for consistency. I ignore the policy because I just put the email into Spam instead of bouncing on policy=reject, but that's a personal choice.
If anyone wants to do it through a Sieve client:
# rule:[DKIM/SPF/DMARC Fail]
#Suppose any one of the following conditions hold for an incoming email:
#1. SPF fail
#2. DKIM fail
#3. DMARC fail
#Then, this incoming email will be
#1. Relocated into the Spam folder.
#2. Have the $untrusted flag assigned.
#3. Have a color flag, orange, assigned.
if anyof (header :regex "Authentication-Results" "(\s|;|^)spf=fail(\s|;|$)"
, header :regex "Authentication-Results" "(\s|;|^)dkim=fail(\s|;|$)"
, header :regex "Authentication-Results" "(\s|;|^)dmarc=fail(\s|;|$)"
    fileinto :create "Spam";
    addflag ["$untrusted", "$cl_2"];
